Simple mining. Rig Groups + miner options
#41
43
there should be “Rigo”
#42
as mentioned above tick (check) the box in front of your miner --> then Assign Group --> then from the drop down menu choose Rigo -->save
#43
for Reload right? and I can use exodus for btc and eth address?
#44
ja exodus has multiple currencies
#45
Seems to work for eth, 7 restarts in short time normal to start whit?
#46
just as a tip gtx1080 are really bad for ethereum, 71MH is not very good , zec is a lot better, every time you restart your rig ,the counter will go up
#47
have a look at this here you can check what would be the best to mine
#48
Well done for helping out ! … Very informative for other noobs like me :slight_smile:
#49
Hi
I want to build mining rig for etherium and other coins but not bitcoins as they say its expensive
and hence no returns on investment or may be less. So i need suggestions that can i go with etherium mining now, and what others coin i mine?
A 6 GPU rig is i can invest now and may be i can increase later, for now only 6. My electricity cost will be much less. So i am not worried about that.
  1. I wanted to buy Radeon vega, but shall i buy 56 or 64? please i need specific reasons i will be very thankful. As i read many people are suggesting Radeon over nividia. I am investing very hard earn money. so please help me out. Which one shall i use nividia ? and which one then? or radeon vega 56 or 54?
  2. motherboard?
  3. PSI
  4. All other devices and equipments?
  5. Total cost?
  6. How much will i earn per day, week, month or year?
  7. What others coin can i mine with such a system , only Etherium or others coins as well? if others, which one
Regards,
A. Khan
#50
One thing that you have to think of is , what is your knowledge in computers ? The reason i ask is , AMD RX/VEGA can be a real pain in the a… . I have 4 rx580 cards , and they are only good if you know how to BIOS Mod them. I have 9 Vega 64 and after a lot of playing around they are working with out a problem, and they are very profitable , if i could get my hands on some more i would buy more , but only vega64 because i don’t want to deal with bios modding the vega56 so that its like a vega 64. With nvidia its very easy , you buy them , unpack,install and adjust the OC settings , that’s it . So that’s the reason why i’m going with the Nvidia 1070ti
I always do a goil calculation , meaning , My goal what i want to have in sols/s (Example 10000 sols/s) and what it would cost me to reach that goal, also calculating in the power costs .
Example 10000Sols/s ZEC is my goil (power cost 0.175$ kw/h) and (card prices hier in switzerland) (all rigs are 8 card)
For an 1060 6g build i would need 4 rigs (initial cost 11000$) (9860 sols @ 2890 Watts 3.4sol/w) = 2915.-$ profit = ROI 3.77 months
For an 1070ti build i would need 3 rigs(initial cost 14079$)(11760sols @ 2760 watts 4.26sol/w) = 3578.-$ profit = ROI 3.93 Months
and for an 1080ti build i would need 2 rigs(initial cost 14626$)(11200sols @ 3200 watts 3.5sol/w) = 3326.-$ profit =ROI 4.39 Months
all these values are real world values that i took from my own mining farm (over 100 gpu’s ) (10603g_10606g_1070_1070ti_1080ti_vega64_rx580_rx480)
so speaking of long term , if you do the math the 1070ti is the best out there.
In the price calculation was included number of PSU`s @1200watts each ,risers,ram,cpu,and motherboards.
PSU = corsair platinum 1200W
Motherboard = asrock H110 PRO BTC+
#51
Thanks :blush:. If i want to build
6 gpu rig and my budget is 5000$ or less.
What gpus shall i choose?
What coin can i mine?
How much can i earn?
I am in sweden. Electricity cost is not a problem for me so exclude it. I read and radeon vega 64 people say are good for etherium and a lot of other coins as well.
#52
like i said , if you are comfortable playing around in the windows registry , the vega are quite good , but they are good for the CryptoNight and Ethash, And the Nvidia is good for Equihash and ethash.
but just have a look at whattomine.com , there you can put in how many cards you have , and it will tell you your profit
#53
5000$ will get you started, and you can add cards later. Did you look at this https://www.nicehash.com/profitability-calculator? Pay out in btc.
#54
Thanks. Just looked it now. Are these radeon vega 64 or for that matter other gpus, as i am living in a student corridor and i have no extra space. We are six people in corridor so six separate rooms. So shall i go with 2 or 3 . If they are not noisy i can buy 6 and then scsle it up as you saud. But if noisy then i ask for your suggestion . How many can i buy and earn ?
#55
They will make noise and heat.
#56
If you chose to go whit nicehash please understand the risk
#57
what did you decide on doing for oc the 1080?
#58
Hi mrs am Samuel am from west Africa Ghana new to this bitcoin mining pls i need a help from use just started using the simple Mining am ask of Miner OPTIONS i dont know what to do can you pls guide me
#59
Which coin are you mining and what hardware do you have?
